Track Grouping for timeshift.
I’d like to see a Track Group feature that allows you to select the whole group and then allow time shift of all tracks starting at a selected point.
If the selected point happens to be within a track: options: slice it in 2, move it all, or move everything after that track’s segment.
This would really help audio book /radio play production.
You can move multiple clips at the same time, by including all the clips that you want to move in the “Selection” (https://manual.audacityteam.org/man/audacity_selection.html). If you then click and drag with the Time Shift tool from within the selection, all selected clips move together.
There is also the “Sync-Locked Track Groups” feature: https://manual.audacityteam.org/man/sync_locked_track_groups.html
