I have an album in the form of several wav tracks which produce tiny pops/clicks in between if played consecutively. Merging it into one large file doesn’t help. Can these clicks be removed in any way? Any suggestions are welcome
It’s probably [u]DC Offset[/u]. That link shows one possible way to fix it.
Or since “DC” is zero Hz, a high-pass filter at about 20Hz will remove it, but it might leave a click at the beginning.
A fade-in and fade-out should also fix it no matter the cause, since you can fade to-from complete silence. They can be short fades of 100ms or so if you don’t want to hear the fades.
