Track alignment errors when opening 2.4.2 projects in 3.4.2 version
Hi! Just updated to 3.4.2 version. When I open multi-track projects I made in 2.4.2, the stereo track audio does not align with the mono tracks the way I had it in 2.4.2. It is offset incorrectly, so sounds are overlapping that should not be.
Any advice, or is this just a bug that needs to be fixed?
Thank you!
