Totally New to Audacity
I am a newbie, just installed audacity 3.1.3 and want to create a recording using overdubbing. I clicked on a Youtube and the first thing I was advised to do was to turn on overdubbing using the Transport option. This option is greyed out on the version I just installed. Do I need something else. Running latest Windows 10 updates.
Can you help me get started?
Henry
[u]Tutorial - Recording Multi-track Overdubs[/u]
I am using Windows 10 and version 3.1.3 and have recorded the vocal shown in the attachment. I want to listen to this while adding chords by playing them on an autoharp through the same through the same mic that I used to record the vocals adding the chords to the existing recording of the same tracks as the vocal recording.
I can’t find a way to do this. Any help greatly appreciated.
Otrman AKA Henry
https://manual.audacityteam.org/man/recording_preferences.html
There will be a slight delay apparent on playback, which you can measure/correct …
https://manual.audacityteam.org/man/latency_test.html
[ Once measured & corrected for your hardware you don’t have to do it again ].
