# Запись инструмента
**URL:** <https://forum.audacityteam.org/t/topic/9367>\
**Category:** Русский\
**Created:** [June 23, 2009, 1:40pm UTC](https://forum.audacityteam.org/t/topic/9367 "2009-06-23T13:40:27Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![docmccoy](https://forum.audacityteam.org/letter_avatar_proxy/v4/letter/d/bc8723/32.png) [@docmccoy](https://forum.audacityteam.org/u/docmccoy)\
**Post date:** [June 23, 2009, 1:40pm UTC](https://forum.audacityteam.org/t/topic/9367/1 "2009-06-23T13:40:27Z")
</div>
Добрый день
Читаю манул по данной программе о записи:
> Part 4 − Recording with Audacity − Part 4
> 1. Create a new project
Все понятно
> 1. Check the preferences
> Make sure your playback and recording device are set. If you’re going to record a stereo signal,
> check the “Record in stereo” checkbox in the Audio I/O preferences.
Теперь не понятно. У обоих playback и recording устройств есть много вариантов выбора, что выбирать? чекбокса “Record in stereo” в упомянутых настройках НЕТ! Видно писали для старой версии документацию
> When picking a device to record from, make sure you’ve set up all the connections properly, such as
> plugging a microphone in to the Mic Input, and any other device in to the Line In of your sound
> card. Then check that the gain level knob(the amount by how much the input should be amplified) of
> the mixer of your soundcard is set right.
Первое предложение ясно - я воткнул бас гитару в усилитель стандартно. + воткнул переходник джеком в усилитель и миниджеком в компьютер (звуковую карту) на месте входа Line In. Второе предложение - где этот миксер звуковой карты?
> Since most soundcards can mix the inputs back in to the outputs, the easiest way to test your
> microphone is to speak in to it while playing with your sound card mixer. The sound card mixer is a
> piece of software either provided by the sound card maker, or by the operating system you’re using.
> The Windows mixer is pretty straight forward, though some soundcards bring their own along. The
> Mac’s mixer is controlled via the Sound Control Panel, and the Linux users have a variety of mixer
> applications at their disposal. Just make sure they work before yelling at your screen that nothing
> works.
Здесь опять же упоминается миксер, но конкретно ничего. Наверное потому что они бывают разные. Но все же, к примеру какой использовать мне и как вообще проверить есть ли он?
Короче, кто умеет записывать свою игру с помощью Audacity? Подскажите что мне нужно сделать. Спасибо
Костя
