Hello All,
Does anyone know how I could generate a simple tone in the tone generator and pan the volume to zero and back to normal x number of times per second, ie 4/sec, 8/sec etc, but keeping the tone frequency the same?
If you just want to modulate the amplitude,
you could do that with Audacity’s native tremolo effect
https://manual.audacityteam.org/man/tremolo.html
If you want to pan you’ll need a plugin: Panning (LFO) …
Thanks Trebor i’ll check it out. So if I generate a Tone of 100hz and under Tremelo settings, is the Frequency in HZ how many times/second the volume goes to zero
OR
the frequency used to create a second tone above or below the original frequency; ie 104 hz or 96h ?z
You have to dial-in 100% wet for the volume to go to zero.
It goes to zero at the Hz rate: 2 Hz is twice per second.
Thanks Much. Exactly what I need to know.
