ver 4.0.0-beta.2.261621301
I would LOVE to have the option to add Export Audio icon to this section of the menu bar.
I don’t have a use for the Share audio option … for example
The idea at one point was to put export and sharing options into the currently greyed-out Publish tab. Why it’s up there only @teetow knows – and where the mixer goes once it gets added
If indeed that is where the Export audio will be located, it still would require 2 clicks. Same as going to File > Export audio. Having it as an option in the menu bar would eliminate that extra click.
I know … small issue, but it does make a difference in my workflow ![]()
you know what? Given that there’s this new customizable toolbar, why shouldn’t there be a button for this? There’s space anyway.
Exaclty!! ![]()
I’ve added a couple more:
I don’t expect this PR to get merged right away (ie for the next beta), but it become relevant sometime down the road
