Tips for noise reduction
Hello :slight_smile:
I’m currently working on an engine record and I try to remove an “air” sound with Audacity. I’ve tried high pass filter and then noise reduction, here the original sample and the edited sample. But I think better is possible, however I don’t know how. Do you have some tips on Audacity or Adobe Audition?
Original sample: https://mega.nz/#!tNVnSYgR
Edited sample: https://mega.nz/#!cdUxHICC
Thanks
Those links are asking for an encryption key.
For this kind of question I would recommend attaching short audio samples in WAV format. See here how to post an audio sample to the forum: https://forum.audacityteam.org/t/how-to-post-an-audio-sample/29851/1
