I’m using Audacity to line up drum tracks that I recorded in another program.
When I move a track using the timeshift tool, then solo the track to export it, it hasn’t moved from the original spot.
Basically, my timeshift moves aren’t being printed.
I tested out using a single snare that starts at 0. I moved it 5 seconds to the right, mixed it down…still starts at zero when played back.
Does anybody know why the export process won’t comprehend the moves I make and print them?
The Get Out Of Jail card is generate a silent track by itself (slightly) longer than the show. Select that track and your time shifted work for export. The export time should be perfect.
There’s a more convoluted way to do that and I need to look it up.
This is the more comprehensive, bulletproof method.
https://forum.audacityteam.org/t/how-do-i-export-tracks-in-sync/45985/13
