timeline problems
I cannot record. When I try to do so, the timeline has a red triangle on it and the line flashes. What’s wrong?
What are you trying to record?
What settings have you selected?
Has this ever worked?
I’m recording albums and this is the first time it’s happened.
How?
Are you using a USB turntable? If so, check the USB cable and reboot the computer.
