HI, I’m having a problem with the time track feature. I’m using 2.0.2. When I add a time track, no vertical scale shows for the layer. It’s just blank. Attached a JPEG for reference. Any idea what the problem could be?
The current version of Audacity is 2.0.5. It is available here: http://audacityteam.org/download/
If the issue also occurs with 2.0.5, try making the time track a bit taller (drag the bottom edge of the track down with your mouse.
What is the “range” set at?
Thanks. The range was just the default 90 - 110 when I noticed there was no vertical scale. Loaded 2.0.5. to another laptop and the scale shows up. For the one that still has 2.0.2., do I need to uninstall it before loading 2.0.5.?
If 2.0.2 was installed in the default location using the Windows installer, then you should be able to install 2.0.5 over the top.
If you’re unsure, there is no harm in un-installing 2.0.2 first.
