Time Stamps in Labels
I see that when I export labels, the time stamps are in seconds and milliseconds. Can I change this to simple minutes and seconds? Milliseconds are good for precision editing, but I need a rougher count for mapping the overall project.
Thanx
There is no built-in option to do that. (The high precision allows label tracks to be exported and imported)
If you’ve got a spreadsheet application (such as Excel or Calc) then you should be able to use that to convert the times to whatever format you prefer.
(this may help: https://www.excelfunctions.net/seconds-to-time-excel.html)
