Time stamp modification when there are no changes
Continuing the discussion from Audacity changes "Date modified":
I always used date stamps to sync files across multiple devices but that doesn’t work anymore with this idiotic changing the file modification date stamp even if there are no changes to the file - simply opening a file, not modifying the content in any way should not change the modification date. I would much prefer the older file structure in that case. I have been using Audacity for many years. Even when you specifically say “Don’t save” it still updates the time stamp. Phil
Yes, see the comments posted in the link you provided. If you wish to have a discussion with the developers about this issue, you can create an issue on github here: Issues · audacity/audacity · GitHub or comment on the #dev-general Discord channel here: Audacity dev
