Time-Shift
I’m on Version 2.3.2 of audacity
Mac system Catalina 10.15
Time-shift is totally missing. I don’t even see it in the help drop down. I’ve spent over two hours combing through every help function I can find and nothing is working.
Recreate the problem by doing any search in the help box for time-shift or time shift or any other variation and you’ll get nothing. I tried almost every item in the drop down and nothing worked.
I’m not sure how to insert an image here - basically it’s just the help drop down with the time-shift missing and no way to find a work around
Thank you
Do you mean that you are not seeing the Time Shit tool in the Tools Toolbar - or are you noty seeing the Tools toolbar at all?
See: https://manual.audacityteam.org/man/time_shift_tool.html
2.3.2 and 2.3.3 alpha test build on my Macbook Pro with 1.15 Catalina both have the Time Shift Tool - and it works properly.
