I’d like to add a time shift into a macro for 31.5 seconds.
Is this possible?
If so, how do I do it?
Thank you!!
Is this possible?
Thank you!!
You can’t do it with the Time Shift Tool because that requires mouse interaction. What you need to do instead is to make a Macro that will select the audio that you want to move, Cut or Split Cut, select where you want to move it to, then paste.
