the sound of the guitar goes and comes
Hello…i am recording with Audacity 2.4.2 on Windows 10 updated…I connect the cable of my acustic guitar on
BEHRINGER UM2 and than usb cable to the PC …After that i register the listening of the guitar is like if there was the phaser or the echo.i check in the effects that ECHO and PHASE and are not enabled and in the guitar too…i think there is something to arrange to PC(HP fq0026nl Notebook, AMD Ryzen 5 4500U) option audio…but i dont find it.i try directly the guitar connected to the pc and it is the same…so it is no the behringer…latency :question: do you understand :question: do you know what can to be :question:
Thankyou
prova1.aup (2.7 KB)
Make sure any [u]Windows “enhancements”[/u] are turned off.
Make sure you’ve selected the actual USB device as your [u]Recording Device[/u]. (You shouldn’t be using “loopback” or “stereo mix”, etc.)
FYI - An AUP file by itself doesn’t contain any audio. (The small file size is a clue. :wink: ) [u]How to post an audio sample[/u].
Thankyou for your answer…i will try It soon!
