The program will not start
I am trying to run the program on a computer with windows vista and whenever i attempt to start it there is no response at all, after I downloaded the program and tried to start it and with no result, I reinstalled it multiple times and installed the zip file and there is still no change. Any advice?
Remove all versions of Audacity from your computer, then reboot the computer.
Download “Audacity 2.2.2 installer” via the Audacity web site: https://www.audacityteam.org/download/windows/
Run the installer (you may be prompted for your admin password), and look for the option to “Reset Preferences”. Select that option when it comes up, and continue with the installation.
On first run, confirm that you wish to reset preferences.
