Import more than 10 waves with names 1,2,3… and the order changes to something like in the picture. It’s painful when the natural order is needed to combine these waves. Could this be avoided?
By the way, is it possible to combine these waves simultaneously?
Audacity doesn’t import files as natural number sort, so you would need leading zeros in the names of the files to achieve import of the files in correct order.
Audacity does not have an append import feature yet that would attach files end to end. We have a feature request system and if you like, you can “vote” for append import. A full featured append import would probably have options for importing files in natural order, in date modified order and so on.
For now, you can click above the Mute / Solo buttons of a track and drag it up or down. When the tracks are ordered correctly, you can join them into one track by using CTRL + A to Select All, then Tracks > Align Tracks > Align End to End, then Tracks > Mix and Render.
Thank you Gale! Adding zeros and making them the same digits! It works! And so does the mix and render buton! So happy!
Thank you a lot!
