Hello, I have a problem with the Audacity application. When I play the audio file on the application, it plays without sound. I installed the latest version of the application, and the problem still exists
You may need to select the playback device in Audio Setup. If your device isn’t listed (e.g., if you switched it on after you opened Audacity), select Rescan Audio Devices.
thank you its worked
