In Audacity 3, the [ and ] shortcuts were designed to allow the user to define a selection while playback was happening. While playing or paused, the [ shortcut moved the cursor to the playback position in anticipation of defining a selection. The ] shortcut made a selection from the cursor to the playback position. These selections were made without intervention from the user.
See Select Menu: Region - Audacity Manual
I shouldn’t have to explain why this is incredibly useful.
In Audacity 4, the way these commands operate has changed radically.
The [ shortcut throws up a dialog titled “Playback position”. You must enter a time that is left of the playhead. The default is “00:00:00” regardless of the cursor position. You enter a time (that is before the current position of the playhead) and then a selection is made from that time to the playhead. Of course, the playhead has moved quite a bit while you’re entering that number. If you enter a time that is after the current position of the playhead, nothing happens.
Similarly for the ] shortcut, where you must enter a time that is after the current position of the playhead.
I have no idea how these commands would be used in practice. Are they meant to be used when in Pause or Stop mode? Why have two commands for a selection that ends or starts with the playhead position?
In Audacity 3, when playback was stopped, these commands allowed the user to adjust the selection precisely. The [ shortcut put up a dialog where the current time of the start of the selection was already entered and the user could tweak it. Similarly for the ] shortcut.
I was going to raise this behaviour as a bug on Github until I realized that the commands were working as intended. This was a conscious design decision.
Select | Audacity Manual
Why?
Why indeed.
There is an existing issue to return to the same functionality as AU3, but unfortunately, there’s no timeframe set for fixing it:
David, thanks for finding that Github issue. It was opened by dozzzzer so maybe it will get some attention.
yeah, I can tell you for sure that this wasn’t an intentional design decision.
