Have played around with this program 2.2, does everything I need. wish I could send a check but i’m living in my brothers garage for a bit, thanks lil sample
A good performance , but the recording is mono.
If you used stereo you could put the overdubbed vocals wide so it sounds like different people singing together,
(because they would then sound like they’re in different places in the stereo-field).
I can only approximate the effect because I only have your mono mix to work with …
There are many free psuedo-stereo / stereo-widener plugins
this is a good one … https://www.youtube.com/watch?v=P819NzjN4rw
Thanks for the tips and hints, hurricane getting close, NC, gonna have a few good days to pick and record. yall have a good one.
