Hi Koz, attached is a test clip as requested. Tho again, prior to running the RMS Normalization/Limiter effect in audition file, noise floor passed ACX Check at -63.4 dB with RMS at -27.9 dB; after running RMS Normalization/Limiter, noise floor was at -67.0 dB and RMS passed.if that helps at all. Thanks so much.
After you apply the tools and got all the good readings, export a WAV sound file and post that.
