Hello,
I have ubuntu 22.04 and latest audacity.
I changed my /tmp to be tmpfs, so at every reboot tmp start as empty, do not retain any directory created in it.
If I set audacity “Temporary files directory” as /tmp/ and restart audacity, it says it does not have a temporary directory.
If I create /tmp/audacity as user running audactity and set it as “Temporary files directory” then audacity can use it.
Problem is I will need to pre-create this /tmp/audacity after each restart.
Strange thing noticed is that if /tmp/audacity is own by root with 777 audacity cannot use it and complain again
If I change the owner of /tmp/audacity to OS user running audacity then it start ok.
Thanks
