I’m new to Audacity and sound editing. I’m cleaning up hours of audio (produced by Android Pixel 2 XL) and would appreciate advice for removing a recurring pattern.
One of the speakers has a “smacking-umming” tendency. I’ve attached a sample.
Manual cleanup is torturous but I can’t figure out how to remove the patterns programmatically. The patterns are variable and they are distributed through the recording, so Noise Reduction / Noise Profile is not an option. Is there a technique that is better than manual editing?
Thanks for your help.
