Tascam-428
I have a Tascam-428 - does Audacity work with the 428? If so, and suggestions on how to get started with it?
Thanks
Clem
The only thing I was able to find was that it’s old and had terrible support when it was new. Quite a number of people had trouble getting it to work because of drivers and technical support problems.
Audacity doesn’t support anything. It depends on the computer internal sound support (drivers, libraries, etc) and then tags along for the ride. Typically if Windows Audacity doesn’t work, then the Windows Sound Recorder doesn’t either. The whole thing fails.
On Windows?
If you can get it to work with Windows Sound Recorder, we can most likely help you get it working with Audacity.
I guess my best bet then is to try Audacity with the 428 and see what I get.
Thanks for the info.
Clem
