tape to CD
Bonjour. I have an Encore “tape2usb” machine that allows me to covert my old tapes to digital format. Unfortunately, I can’t figure out how. Any thoughts?
This set of tutorials from the manual should help: http://manual.audacityteam.org/help/manual/man/tutorial_copying_tapes_lps_or_minidiscs_to_cd.html
Especially this one: http://manual.audacityteam.org/help/manual/man/recording_with_usb_turntables.html
normally you’d hook up your rca cables from the cassette player to the rca jacks on the adapter and the usb cable from the adapter to a usb port on your computer. Then when you are in audacity you should be able to hear the cassette playing .
But not in this case - the poster has an integrated tapeplyer/USB device so only the USB cable will be used.
photoman’s advice holds good if you have a separate USB sound card and separate tape player.
