I’m installing equipment that captures discussions in a small theater for the purpose of sharing the ideas with other people offset in time, distance, or both. It’s pretty simple. The microphones are Shure MX393 Stage microphones…
…feeding a Peavey PV6 analog mixer and then onto balanced audio tie trunks to another location. When they arrive, they are hum rejected and unbalanced with a Jensen transformer package…
http://www.cs1.net/products/jensen_transformers/PC-2XR.htm
…and then plugged into a Behringer UCA202. The computer is pretty much irrelevant, but UFN, it’s one of our linux machines.
When I did the initial sound tests everyone was shocked at how clear and crisp everyone’s voice was. That’s because nobody had ever heard a correct, uncompressed live recording with no processing or distortion before.
And that’s the problem. Because the system is completely unrestricted, it overloads at the drop of a hat.
No shock there. I’m expecting it.
Most of the time, the clipping isn’t objectionable and doesn’t affect the work. I suspect we are going to find a happy medium between overloading and the eventual customer’s ability to turn the loudness up far enough to hear the work. Low volume is actually much more of a problem.
But I wouldn’t mind gentle limiting somewhere in the chain so to make the process less user intense.
Oh, and you can’t use post processing. The turnaround is less than an hour and the show is an hour long. Once the computer gets the last of the show in real time, it essentially posts. The Operations people grab it in mid-air and produce the international copies.
Next!
As an experiment, I put one of the tests through Chris’s Compressor and what it did to the background room noise was pretty entertaining – and not unpleasant, but wholly unworkable for the actual performance.
