Hello. I am using Windows 7 and Audacity 2.1.0. I wish to export songs from Audacity to Studio One 3 (Professional), hereafter “S1,” using “export multiple” so that each track is exported separately. I wish to export the Audacity files as FLAC files into S1. In attempting to do this I have encountered a problem: the files do not remain in sync. This problem occurs even when silence is added to fill all vacant spaces between events on Audacity tracks prior to exporting. I assume I am doing something wrong and that there is a fix for this that is far easier than moving segments around in S1 until they line up as they do in Audacity.
QUESTION: How do I fix this so that the files remain in sync after transfer? Timestreching (or not) in S1 does not take care of this, and I think that could because some of the files exported from Audacity may be and are likely missing tempo markers or other information essential for timestretch to work. Sync-locking the tracks in Audacity makes no difference. I understand the difficulty and solution may lie in S1, not Audacity, and I am working on the problem from that direction as well.
Thanks in advance,
NER
