I’m trying to write a Nyquist plugin to switch between effect 0 and effect 1. Here is the code
;nyquist plug-in
;version 1
;type process
;name “Flip Sound”
;action “Flipping…”
;info “Flip Frequency-Based or Sample-Based Sounds Upside-Down.”
;control text “Spectrum Or Waveform?”
;control md “Flip this” int “0=Frequency 1=Waveform” 0 0 1
;control text “We currently do not support different scales, reverse, time-and-frequency swapping or frequency-analysis.”
;control text “This plugin was a pain-in-the-butt to make, and took all night. Please, enjoy it. Until help is made, you could try using a different program to…”
;control text “1. Flip semitones, like Frequency Spectrum, except frequencies are set in musical notes”
;control text “2. Flip time, play in reverse”
;control text “3. Swap time and frequency, turn spectrum so Horizontal and Vertical is reversed”
;control text “4. Flip frequency analysis, turn spectrum in negative”
;effect 0
(lowpass6 (mult 1 (highpass6 S 20) (hzosc 20000)) 20000)
;effect 1
(mult S -1)
Hi Winston, and welcome to the forum. I guess you’re the guy I wrote to on facebook?
To switch between effect 0 and effect 1, you need to do something like this:
(if something-is-true
(effect-0)
(effect-1))
In the case of your code, I assume that you want “effect-0” when “md = 0” and “effect-1” when “md = 1”.
(if (= md 0)
(effect-0)
(effect-1))
Note that we don’t need to test if md = 1 because there are only two options.
The general syntax is:
(if <condition>
(do-this)
(else-do-this))
Some additional notes:
It is highly recommended to write all new code in the latest version syntax (version 4). The most obvious difference between version 4 and earlier versions is that Nyquist effects now use TRACK (or track) to access the selected audio. (previous versions used “S” for this purpose).
“S” was a poor choice in early versions of Audacity, because “S” could also represent the value 0.25 (as shown in the Nyquist manual: https://www.cs.cmu.edu/~rbd/doc/nyquist/part12.html#index973)
