Suggestions for small omnidirectional mics?
Hello,
I want to wire up some small omnidirectional mics, I got some teeny weeny ones from the electronics shop I managed to solder together for about $2 each, but the quality isn’t great. Anyone know some good quality mono microphones that are tiny and I can just solder contacts on to?
I have one similar to this at the moment: http://en.wikipedia.org/wiki/Electret_microphone
want something similar to install but higher quality?
I’m a fan of the Radio Shack 3013 microphone. It’s designed as a tie-tack microphone, but you can use it as a terrific group microphone by making it into a Fake Pressure Zone microphone with a piece of wood and towel.
No soldering needed and it plugs straight into the Mic-In of your Windows Laptop.
http://www.kozco.com/tech/audacity/pix/3013PressureZone.jpg
It’s your capsule already tricked out with all the stuff you’re going to have to solder anyway.
Or you could use one of these.
http://www.radioshack.com/product/index.jsp?productId=2062215
http://www.radioshack.com/product/index.jsp?productId=2062216
Panasonic WM-61
Right then. Here’s the release version.
http://www.kozco.com/tech/audacity/pix/3013PressureZoneFinal.jpg
I’m installing that one in one of the training rooms tomorrow.
