Suddenly Audacity will not record
Hi, I’ve been using Audacity for some time to record talks initially recorded on cassette.
Suddenly audacity has decided not to record. When I click the record button the cursor turns red button doesn’t move and nothing appears t record.
Have I perhaps clicked on something that I shouldn’t have?
Any help or avice would be welcome.
Thanks in advance.
David Bevan
The cursor not moving can be Audacity stopped getting the sound data. How are you getting the cassette sound into the computer? Unplug and replug everything. Restart Audacity and see if that helps.
Thanks Koz, I’ve just this minute plugged it into another USB port and it’s working again.
So problem solved.
Thanks for responding so quickly.
David Bevan
