I have been using audacity for years and I have never experienced this before. Whenever I attempt to open a file (after i click “Open”) after a few seconds, the whole program pretty much collapses in on itself, and I receive no error message.
I’ve tried re-installing the program (I have the latest version, 2.1.2) and shutting down any programs that are not in use. I don’t think it’s my anti-virus, because even when I disable it, the issue still occurs.
I also have plenty of disk space left, although I am currently trying to uninstall some programs I don’t need that take up at least 3 GB of memory.
If anybody knows how to fix this please let my know as soon as you can. Thank you for your time.
267 GB free of 445 GB of drive space
I don’t believe the files are the problem, because I’m unable to open them because Audacity closes out completely before I get to double click the file.
@Gale
While searching for the file I want to open, which don’t take up a lot of space, the whole program exits. There’s no sight of it turning white or an error message, it just completely disappears.
I’ll see if resetting preferences will work.
