Sudden failure to record after updates
I have used Audacity for years with no problem, recording with a Behringer UCA202 interface into a Windows 11 laptop. Suddenly, I can get nothing but a half-second blip, then silence (and sometimes not even that). The monitor on the interface has sound coming through, but nothing registers in Audacity. I’ve checked the input settings and everything seems normal. Suggestions?
Windows updates can enable “audio enhancements”.
Some enhancements will permit speech but attempt to block music after ~250ms
https://support.microsoft.com/en-us/topic/disable-audio-enhancements
That seems to have solved it. Windows upgrades typically make everything less functional, and is just another example. Thanks.
