I am looking to perfect my current audio program that is based on this patent.
After reading it several times I am missing a few key components, most importantly the subliminal messages are created using woman voice on right channel in normal state, and then male in reverse for left ear.
They are hid under a primary carrier that is brownian noise effect on a sound of water so it has no breaks.
I am not looking to discuss wether this technology works or not, those discussions are ignored, Trebors texts won’t even be read and will be completely ignored.
I am looking to perfect my audio, it does have some effect but it’s not as strong as their patented products they have on their website.
Those I can use for a month and the changes will last months because of a different brain wiring.
My own product seems to work while I use it and it does change wiring but to a small degree, and effects usually fade if I don’t use the product every day.
I do have some of their audios I can send over for you to decode if you are skilled at sound engineering and if you could help me create the program I want, I can pay you.
I do have a hard time trusting people because some channels on youtube are known to have negative statements and just are out to harm peoples health and thinking.
So it’d be better if someone created a guide on how to create these audios using the patent. One thing in the patent that I think you have to be a genius to understand is they say “the messages are then converted to electrical impulses”, I have no idea what that means.
I think that’s patent-speak for “record your voice.” This is me doing it with my phone. I used Lossless Voice Memo on an iPhone for good quality work. I shot a test, I cut the recording down to size, applied Audiobook Mastering and produced an ACX quality sample clip.
There can be problems with recording voices at home that aren’t obvious. Let me rewrite that a little.
… using woman voice Only on right channel in normal state, and then male Only in reverse…
No air conditioning noises, metrobus rumble from the street, computer fan whistle, or USB mosquito whine. All of these are perfectly normal problems that home recordists have. If you’re after a scientifically correct production, you have to duplicate the scientifically correct environment that the original testers used. Refrigerator compressor noises and washing machine clunk sounds need not apply.
I told you to not respond here you will be ignored.
Looked at the thread and Doug said use -20 dB to drown it out.
That’s not what their technology is, they drown it out somehow with the near same dB on the primary carrier and the subliminal messages.
I am using human like AI generated voices anyway, they are very clean and WAV format.
Play.HT is very good and I’ve tried several websites, it’s mostly free too.
The Eldon Taylor patent specifies that the words are played backwards, as well as forwards.
Words played backwards can sound like different words: e.g. stop - pots [“phonetic semordnilaps”].
So if this brainwashing worked, the backwards version could contain unintentional messages.
The Eldon Taylor website has a disclaimer …
“The products in this catalog are sold as educational properties only.
No claims are made regarding any medical or psychological condition or impairment”. Frequently Asked Questions – InnerTalk-Store
