I am new to Audacity and I’m using it to edit some organ music.
Sometimes, I need to speed up the performance by using the Change Tempo effect. When I do, I get quite a lot of sub-harmonics generated in the process.
Is there anything I can do to minimise this?
Brilliant!!
I changed the quality settings in preferences and turned on high quality stretching and it sounds great.
Thanks for your help, Steve.
Chris
