streeming via dlna
Hello im new here i am runing windows 10 and have the latest audacity program the problem i have is when i record a dvd sound track via audacity and save it as mp3 then try to streem it via dlna the last 2 minutes of the sound track cut off before the track ends the mp3 file plays fine on my pc right to the end can any one help i have tryed to even carry on recording to the first track again but it still cutts off. thank you.
By default, Audacity encodes MP3s as “VBR” (variable bit rate), which is optimised for music. Some players don’t handle VBR encoding very well, and that could be the problem. Try Exporting from audacity as MP3 and select “Constant” as the bit-rate mode. (I’d suggest setting the “Quality” to 160 kbps, but if you still have streaming problems, try 128 kbps). https://manual.audacityteam.org/man/mp3_export_options.html
thank you for your help ill try it and let you know
Hello i re recoeded the three dvds but it still ends about 2 minutes before the end of the last track i saved them all at 128kbps any other idear s please thank you
Does it play any MP3s (of a similar size) all the way to the end?
Only seem to have had this problem since I up graded to windows 10 it plays mp3 that recorded prior to the up grade to full length
Get one of the files that works correctly, and use this web page to analyze it: https://mediaarea.net/MediaInfoOnline
Copy and paste all of the results into your reply.
Repeat with one of the files that does not work correctly.
Let’s see what the difference is.
Ok I’ll do in the morning at work till 0140
neral
Complete name : Depeche Mode - Berlin 17 March 2017 - Spirit Tour.mp3
Format : MPEG Audio
File size : 87.6 MiB
Duration : 1 h 3 min
Overall bit rate mode : Constant
Overall bit rate : 192 kb/s
Writing library : LAME3.99.5
major_brand : mp42
minor_version : 0
compatible_brands : isommp42
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Format settings : Joint stereo
Bit rate mode : Constant
Bit rate : 192 kb/s
Channel(s) : 2 channels
Sampling rate : 44.1 kHz
Frame rate : 38.281 FPS (1152 SPF)
Compression mode : Lossy
Stream size : 87.6 MiB (100%)
this one is ok
General
Complete name : OASIS LIVE BY THE SEA.mp3
Format : MPEG Audio
File size : 73.7 MiB
Duration : 1 h 20 min
Overall bit rate : 128 kb/s
Album : LIVE BY THE SEA
Performer : OASIS
Writing library : LAME3.99r
Audio
Format : MPEG Audio
Format settings : Joint stereo / MS Stereo
Bit rate : 128 kb/s
Stream size : 73.7 MiB (100%)
Encoding settings : -m j -V 4 -q 3 -lowpass 17 -b 128
this is one of the ones im having trouble with
Does the Oasis track play all the way to the end if you just play the file in an ordinary media player?
I think I’ve sorted it via the link you sent me
The one that works was done using lame 3 99.5
And the one that doesn’t was done in lame 99r
Thank you for your help
