Strange Trumpet Sounds in Audacity.exe (2.1.2)
I saw someone do this with ‘undertale.exe’, so I did this with a few exe files myself. One of those was ‘audacity.exe’ I found something that sounds similar to the music associated with the moon landing (especially if you slow it down more). Take a listen!
https://wikipedia.org/wiki/Fanfare_for_the_Common_Man
It’s the program’s raw bits as if it were imported as RAW. Youll hear all sorts of weird sounds like that when rawing exe files.
Then why did it happen multiple times in the same sequence? This could be a binary file (or something similar).
The reason for repeats in sequence, is the binary loops that were contained. Either its the source code that was translated to binary before saving it as the exe, mustve been repeated. Or something else I can’t remember.
