I downloaded Audacity and successfully recorded half a dozen tracks from YouTube music videos by connecting my computer to my amplifier Aux input, and my computer to my amp headphone socket. (There was no sound, of course, but I didn’t find that a great issue since I was able to judge the end of the recording by watching the video.) For a while, as I say, this worked just fine. But then, all of a sudden, I began to get some odd noise coming from somewhere (see screenshot). can anybody tell me what’ve I’ve done wrong here? Thanks. (W10 A2.3)
Just FYI, this is generally a copyright violation… That’s why there is no “download” button on YouTube… They don’t want you downloading/copying.
With WASAPI loopback as your recording device you can [u]record what you’re listening to[/u] on the computer without any external connections. And, as long as there are no “glitches” you’ll get a clean digital capture with no added noise or distortion.
Like I said, you shouldn’t have to do that. And if you do, you shouldn’t need an amplifier. You can plug line-out/headphone-out from your soundcard to line-in on your soundcard. But, you do need a desktop computer with a regular soundcard. The mic input on a laptop is too sensitive. And with a [u]Y-splitter[/u] you can plug-in headphones/speakers at the same time.
That sounds bad. Could be a component breaking down.
The recommended way to record sounds playing on the computer is, as DVDdoug suggested, using “WASAPI loopback”. Give that a go and let us know how you get on.
