STOPS WHEN I START A GAME
Hi, I have a problem and I don’t know hot to fix it.This program stops when I start a game (etc. the forest…), I recorded and tryed for hours to fix that but nothing’s changed.Before that worked fine just now it doesn’t.
I have win 8.1 and I use fraps to record.And I don’t want to record with any other program, just audacity.hope you have a solution.
thanks
Do you mean Audacity crashes when you start a game, or stops recording?
Does the entire computer crash?
Does the game require exclusive access to the sound card? That will stop you recording with Audacity.
You could try undoing changes you made before the problem started.
That quote seems to contradict itself, but Fraps is appropriate to record game audio and your microphone at the same time. Is that what you are trying to do?
