steve harris plugin
hello
os x 10.8.5 mac pro book audacity 2.0.5 dmg installer
hay ! hay ! hay ! maldita cabessa
yes ! Gale you are prefectly right , i did not notice i was on the spanish forum !
yes its steve harris plugin i did download thems , in witch folder i schould put thems to be abble to use thems ?
thanks very much
bonjour
bien sur Gale ! quel etourduis je suis , je ne me suis meme pas apercus que j’etais sur le forum espagnole !
oui ce sont les plugins de steve HARRIS
afin de les utiliser dans quel folder dois je les ranger ?
merci beaucoup
It says on http://audacityteam.org/download/plugins :
To install new LADSPA or Nyquist plug-ins, place them in the Plug-Ins folder inside the Audacity installation folder.[…] On Mac OS X, it is usually under “Applications”.
If you prefer, you can put them in ~/Library/Audio/Plug-Ins/LADSPA or /Library/Audio/Plug-Ins/LADSPA .
Then Audacity > Quit Audacity and restart Audacity.
hello
i do not see thems ? wrong placement ?
would you see the attachement
thanks
The zip file http://audacity.googlecode.com/files/swh-plugins-mac-0.4.15.zip is not an installer. The user is responsible for putting the extracted files in ~/Library/Audio/Plug-Ins/LADSPA if they wish to do so.
