Stereo recording [SOLVED]
Hello,
I use Audacity 2.1.3
I am trying to make a stereo recording of my vinyl records but i get a two tracks mono recording.
On my screen i can see that two identical tracks are being recorded, at the playback it sounds like only one channel has been recorded on two tracks.
While recording i hear the music in stereo but the playback is mono.
I have tried different ways to plug my cables but i always get a mono recording at the playback.
Please tell us how your turntable is connected to your computer. What you’re describing is “hard” to do digitally, so I assume there’s something wrong with the analog connection. (That is, it’s hard to do accidently or while recording.)
Are you losing the “center”? (Typically the lead vocals & bass are common to the left & right.)
Are you listening to the computer while recording, or through a separate analog setup/connection?
Hello,
My English is approximate but i will do my best to describe my installation. My PC run on Windows 8.
The output of my turntable are connected to a Berhringer phono pre-amp via the input outlet. The output of the pre-amp are connected to the ‘line in’ (blue) of my PC.
The USB cable of the pre-amp is connected to a USB outlet on my PC.
It is hard to tell if i am missing the center, it is more one of the channel i am missing at the playback.
I am listening the playback through a headphone plugged on my PC.
Please try the most obvious solution first, setting the phono preamp to stereo in Windows:
http://manual.audacityteam.org/man/faq_recording_how_to_s.html#rinstereo .
Hello DVDdough,
I have check the Windows properties at the lower right of the screen and the ‘line in’ was set to 'canal 2, 16 bits 48000hz (qualité DVD).
Then i have checked the Audacity preferences section and i did set the recording device to be the ‘line in’ and i made a new recording test.
It works fine now, the playback is in gorgeous stereo.
Thanks a lot DVDdough.
Hello Gale Andrews,
Thanks a lot for your help.
Clément Grenier, Québec, Canada
I will mark this as {SOLVED] then and lock the topic. Thanks.
