recording on USB Codec and built-in mic horrible - staticy, distorted, dropouts… I think I have all the settings the same on this version of audacity as I had on my old Macbook Air (not Mojave I think) - i.e. buffer to 0, 44.1, etc. - went through the FAQs and stuff either didn’t apply or didn’t fix it…
Thanks for posting the solution. I was going to suggest that you reset the buffer to 100 (the default) and then work from there to find the optimum setting - you beat me to it
