Why is there static appearing in the audio when I slightly increase the pitch?
How do I get rid of it? Thanks.
That seems unusual… You can get artifacts (side effects) but I wouldn’t expect “static”.
You can try the Sliding Stretch Effect which is supposed to be a better algorithm (and you don’t have to “slide”).
If you can live with a slight speed-tempo change, the Change Speed effect changes pitch & tempo together (like playing a record or tape faster or slower). That’s mathematically simpler and “cleaner” and the only side effect is the speed change.
