Starting play back at 0 [SOLVED]
I’m using audacity 2.1.1. I am using a click track. When I record a track I don’t like, I click on it to highlight it and then Remove Track. But every time I click on a track, I inadvertently create a new start point for my recording. So when I start the next track, the recording starts wherever I happened to have clicked on the deleted track. I would like to have all tracks start at 0. How do I do this?
thanks
BD
Click the << button (skip to start), or press the Home key.
http://manual.audacityteam.org/o/man/transport_toolbar.html
Or you could remove the track by clicking the X in the top left corner of the track.
Or you could “Undo” the recording (“Edit menu > Undo” Ctrl+Z)
Thank you. That was easy.
BD
