Splitting recording into tracks when recording LP
A very basic question: After I have recorded an LP using Audacity, what is the correct procedure for splitting the recording into individual tracks? I searched the forum for advice on this but unfortunately the article that seems to cover what I want to do refers to a set of instructions which is a broken link.
Please provide a link to this article so that the erroneous link might be corrected.
https://manual.audacityteam.org/man/splitting_a_recording_into_separate_tracks.html
I simply select one song at a time and then File → Export → Export Selected Audio. (Sometimes I export a little extra, then re-open the files and trim the silence at the beginning & end.)
Then I use Mp3Tag to add the artwork and make any necessary edits to the metadata. Mp3Tag works on virtually all audio formats, not just MP3, and you can optionally select a folder-full of files to add the artwork and all other common information at once.
