I want to split an audio file at regularly recurring sound elements, specifically repeated words. Is there a way to feed that information into Audacity, possibly similar to removing static/hiss from files, and have the program section off the overall file into smaller pieces at those points?
I’m using Audacity 2.0.5. I honestly cannot remembering if I got the .exe installer or the zip. I don’t think it matters for this question.
Thanks for any help!
