hi
im recording edison records ay 78 speed but i was told that edisons have to be a 80 speed…my turntable is only 78 45 33 speeds…how i was told audicity can fix this issue…how do i use audicity for this?i using the most recent audicity on a dell insepion computer…with microsoft edge…thanks
You don’t like that solution? It’s the best way… I changes speed & pitch together exactly like changing turntable speed.
Apparently the speed wasn’t completely standardized, the equipment may not have been that accurate, and the standard 78 may not have been exactly 78. Of course, record players weren’t perfect in the days of 78’s either.
The only way to know is from the pitch… If a musician can play-along in-tune with a properly tuned instrument the speed is correct. And if you are not a musician trying to play in-tune it’s probably not that important.
