Hi,
Just wondering if Spectral Editing could have a tool like an “eraser” or “brush” that is set to a dB level based on parameters the user could change. So if the user changes the value of the tool to -25dB, and then drags the tool across the Spectrogram Wave, all the areas that the tool covers would be changed to a dB level of -25. This would allow very detailed and accurate adjustments.
I’m sure it more complicated to program than it sounds as an idea.
Thanks,
Mike
