Lately, I am unable to use Spectral delete or even a timeline delete on specific segments of audio that I wish. I can only select set incremental sections/sizes of audio. Is there a setting which I inadvertently activated? I have attached a screen capture of trying to delete a breathe between senteneces, but am unable to select the exact section of audio which i need to delete. Thanks.
You might want to visit the snapping toolbar and see what it says.
Thank You I will check it out and let you know if it corrected the issue. Much appreciated.
Thank You. I just had to click to turn off the snapping. Now it works. Thanks
