I installed the new Audacity 3.3.3 and now I can’t select the usb source in order to digitalize a record, I’m on a mac Monterey 12.6.8, I tried to restart, select rescan in the transport menu, nothing works, it’s always connected on the microphone of my mac.
thank you for your help.
Tarcis
Windows guy here.
If your device is present under Apple Audio Midi Setup: Change the sound input settings on Mac - Apple Support
then Audacity should be able to find it under the Audio Setup button. (As you mentioned, you may need to do Transport > Rescan Audio Devices).
Thank you for your answer, I finaly find the solution, I selected my source device in the button “audio set up” and then I found it under “recording device”.
…scratches his head…
